When starting Revit together with Naviate, we will check if there is Naviate licenses allocated to your user login.
That check will make sure to have the correct Naviate ribbons visible or greyed out, depending on what type of licenses you have been allocated by your licenses admin.
We will never take a license when logging into Revit and Naviate. The license will be taken (allocated) first time when you start (click) a feature in Naviate.
Access to a license
Not access to a license
Help will always be available.
Release a Naviate license
There is two (2) ways to release a Naviate license from your computer.
Number one:
- Go to Help and your user. Then choose "Naviate Logout"
You will get this message
To access Naviate again you need to restart Revit again.
To get access to Naviate again, you need to restart your Revit session and log in with your user credentials.
Number two
End your Revit session and the Naviate license(s) will be returned to the license server.
