If you are using a Naviate for Revit application, you can now use your Symetri account to access Naviate Help and E-learning in Pinnacle; less need for signing in.
Note: After installation of latest release of Naviate for Revit 2023.1.9 and Naviate for Revit 2024.3
First time you access Help or E-learning from any Naviate for Revit application you will be asked to login using your Symetri SSO credentials and to authorize Pinnacle to your Symetri account.
Now a Pinnacle account is created if you belong to a company with Naviate licenses.
From now on your Pinnacle account will automatically be used every time you access Help or E-learning from any Naviate application if you have a Naviate license connected to your Symetri account.
Note: Naviate 2022 and older versions still uses the same Login as described here.
