Get started with Naviate MCP for Revit
Connect Claude — or another MCP-compatible AI assistant — directly to Revit, and describe what you want instead of clicking through menus.
Startup Guide · v0.13.0
Before you start
You'll need:
- Autodesk Revit 2025, 2026, or 2027 — 64-bit Windows
- A free Symetri account — create one at my.symetri.com
- An MCP-compatible AI client. Claude Desktop is configured automatically during install; ChatGPT / Codex are also supported but need manual setup; see "Connecting a different client" below
Setup
- Install Naviate MCP for Revit.
- Fully quit and restart Claude / Chat GPT Desktop, so it picks up the new server. You may need to right-click on the app running in the system tray to close it. (see image below)
- Open Revit. If Revit was already open during install, restart it too — its plugin only loads at Revit startup.
- Ask for what you want. Tools appear automatically; there's no Revit ribbon tab or button for this.
Two trials, not one
Naviate MCP for Revit and Naviate Accelerate are two different products. Currently, you only need the second if you want the extended toolset.
| Naviate MCP for Revit | Naviate Accelerate | |
| Included | Core Revit toolset | Extended toolset — optional |
| Trial starts | Sign in and accept the trial right in the conversation | After installing separately and restarting Revit, accept its own trial prompt the first time you use one of its features |
Download Naviate Accelerate from My Symetri. If a trial expires, contact info@symetri.com to extend it or discuss licensing.
What's included — Revit tools
Included with your Naviate MCP for Revit trial. Accelerate isn't needed for any of this.
Extended with Naviate Accelerate
Accelerate adds a further set of production and documentation tools on top of the core toolset above its own module, its own trial. See "Two trials" above for how to get it.
Try these prompts
Paste any of these into Claude once you're connected.
Connect to Revit and confirm you can read the open document tell me what levels, sheets, and views exist.
If you need to sign in or start a trial first, walk me through it.
Give me a quick census of this model: counts of doors, windows, and walls by level, and flag anything that looks unusual.
Find all doors on Level 1 and show me their Fire Rating. If any are missing a value,
tell me before you make any change, and confirm anything you update by reading it back afterward.
Build a schedule of [category] with [fields], grouped by level, and show me the result.
Claude Desktop configures itself during install. For anything else — including Claude Desktop if that step didn't run, which can happen when antivirus or network security software blocks the install step that edits its configuration — add the server by hand.
Claude Desktop (manual setup)
Edit %APPDATA%\Claude\claude_desktop_config.json and add:
"mcpServers": {
"Naviate MCP for Revit": {
"command": "C:\\Program Files\\Symetri\\Naviate\\Naviate.RevitMcpServer.Stdio\\Naviate.RevitMcpServer.Stdio.exe",
"args": []
Save the file and restart Claude Desktop.
Codex
Edit %USERPROFILE%\.codex\config.toml and add:
[mcp_servers.naviate_revit]
command = 'C:\Program Files\Symetri\Naviate\Naviate.RevitMcpServer.Stdio\Naviate.RevitMcpServer.Stdio.exe'
args = []
Save the file and restart Codex.
Using the ChatGPT desktop app specifically, rather than Codex? Its MCP setup may live somewhere different — contact info@symetri.com and we'll send the exact steps.
This is just the start. We're extending Naviate's AI tools across more of the Naviate product line — including Naviate MEP, Naviate Fabrication, and Naviate Rebar — so expect more capability here over time.
