Long Arrow Right External Link angle-right Search Times Spinner angle-left
How to install Naviate for Revit 2022 licenses
The process for downloading and installing Naviate for Revit licenses.
Content
  • Download the software
  • Installing Naviate
  • Remove the software
You can access the Naviate product downloads on https://www.naviate.com/downloads
You are prompted to login to access the download page for Naviate. If you don’t have an user, please Sign-Up and Verify your email and you will have instant access to the download pages.
undefined
Download the main version and if any the latest update for the product you want to install.
undefined
Installing Naviate
When you have downloaded the software, you want to install, double click the installation file and the installation wizard will start.
To install, make sure that you exit any programs that you have running, including Revit.
undefined
The following dialog boxes will appear:
undefined
The next dialog will tell you about the “Symetri privacy policy” and the Software license and subscription terms. Please click the links to read the through. By clicking Next, you accept all terms and conditions related to the software.
undefined
In next dialog you must choose the local configuration you want to use. By choosing this you will get the template files and families based on the language you choose. It has no impact on the language in the product itself. That will always be English.
undefined
Always accept the default install location.
undefined
Now you are all set to install Naviate. This is the last chance to change language or folder before the installation starts.
undefined
The installation will commence.
Click the Finish button to finalize the installation.
undefined
Remove the software
The application is an add-in which will be run inside an Autodesk Revit application. Uninstalling the application can be done via the Control Panel.
undefined
or via the Remove tool if you re-run the installer.
undefined
Resources
