Log file error messages
2 min. readlast update: 11.25.2026
Each job writes a log file. Find the message from your log file below to see what it means and how to fix it.
Error while creating the first version on Autodesk
Symptoms
A file is not created in the destination folder, and the job's log file shows this message:
Error happened while creating the first version on Autodesk
Cause
Autodesk rejected the file when Nebula tried to create it in the destination folder. Possible causes:
  • Insufficient permissions on the destination folder. You don't have the permission level needed to create files there.
  • Required attributes are not provided. The destination folder has custom attributes marked as required, and the transferred file has no values for them.
  • The file name does not meet the naming standard. The destination folder has a naming standard, and the file name does not match it.
Solution
  • Permissions: ask the Project Admin to give you at least Edit permission on the destination folder.
  • Required attributes: ask the Project Admin to make the attributes optional for the transfer, or make sure the source files have matching attributes with values. See also Attributes or version history are missing in the destination in Transfers help file.
  • Naming standard: rename the file in the source so it matches the destination naming standard, or ask the Project Admin to adjust or disable the naming standard for the transfer.
When you have fixed the cause, run the job again.
