Make sure you have both the MSI and CAB files in the same folder, then double-click on the MSI file to start the installation. Then follow the on-screen instructions, and note the following:
- When entering customer data, please type in no-nonsense values! The information is used to simplify traceability for efficient support. You will only need to enter the information once since it is shared between all Naviate installations an will be filled in beforehand the next time you run a Naviate product installation.
- Select the proper type of licensing and enter the license number for the correct Naviate vertical supplied in the e-mail. If you are using network licensing, enter port number@server name as mentioned in the instruction video.
- If you would like to install more than the default country content library, select "Custom Setup" and select the content you prefer.
