Naviate Architecture 2025 and 2026 v26.3.2 - Naviate Favorites: Never-ending Revit loop
Naviate Architecture features are now available in Naviate Favorites, allowing you to create a personalized Naviate A/AC ribbon with your most-used tools.
Warning:
If Architecture and Accelerate are used together, they must have v26.3 version or higher to ensure compatibility (especially for the Favorites feature). Older versions may cause issues!
There is one specific case to be aware of:
If AC is on an older version (lower than v26.3) and the user is using only the custom toolbar, installing the new version of A (v26.3 or higher) may cause Revit to enter a never-ending startup loop. In this case, Revit will not open successfully, which also means the user may not be aware of the compatibility issue, since the warning message appears only after Revit starts.
If you are using the custom toolbar before running Revit, it's highly recommended to update AC to version 26.3 or higher. After updating AC, the issue should be resolved.
