In this article you can find:
- Find & Replace video
- About Find & Replace
- Workflow
- How to use Find & Replace
Find & Replace
About this feature:
With the help of the Find and Replace command, you can Find and Replace common parameter values of selected Revit elements. You can select elements of the same category or multiple categories.
Workflow
- You can pre-select elements and run the tool or be automatically prompted to select after you start the tool. After the selection of elements is done, you will be presented with a dialog.
- Select what parameter to perform command for
- Type the value to find
- Type the value to replace
- Select replace
- List the common parameters between the selection. One parameter must be selected to find and replace.
- Drop-down or type in a parameter value that you would like to find in the selected parameter.
- Drop-down or type in a parameter value that you would like to replace in the selected parameter.
Notes and Tips:
This feature currently only works with instance parameters.
If multiple categories are selected, only command instance parameters will appear.
Use other Naviate selection features like Live Selection to pre-select elements before running the command.
