Help Menu
Help has information and links to help you with Naviate.
In About you have access to:
- About: Check what version of the software you are using
- What’s New: Find out what improvements, updates, and bug fixes happened in the version you are using.
- Help F1: you can hover over any feature and select F1 which opens the pinnacle help page of that feature. Only available if you have access to Pinnacle.
- Support: allows you to send an email to our support team
- Live Support: Access to live support. Live support is included in the Premium support agreement for Naviate.
- Symetri e-Learning: Access to all help documentation on Pinnacle. Only available if you have access to Pinnacle.
- Configure Naviate: Change the region for the loaded toolbar.
- Check for updates: Check if there are any updates available for download.
- Ideation Portal: Add ideas for new features or improvements and upvote other ideas already in the ideation portal.
From the login dropdown you have access to:
- Symetri License Portal: Access to the Symetri License portal. You can see your licenses and download latest versions.
- Logout: Will log you out of Naviate.
