In this article you can find:
- Quick PDF Export video
- About Quick PDF Export
- Workflow
Quick PDF Export
About this feature:
This tool lets you export views or sheets to PDF files.
Main features of the tool are:
- Export a sheet/view as active view using Revit’s pdf export setting
- Export pre-selected sheets/views at the project browser using Revit’s pdf export setting
- Export all sheets in pre-selected or open Sheet List using Revit’s pdf export setting
- Export all views in pre-selected or open View List using Revit’s pdf export setting
Workflow
- Open view/view list/sheet/sheet list or pre-select views/view list/sheets/sheet list in the Project Browser
- Run Quick PDF Export command under the Print/Export/Import tool
- Select one of the Revit’s export setting
- Select or enter a file save path
- Click Export button to complete process
The file name option lets you to enter file name for Revit’s setting that has enabled combine selected views and sheets into a single PDF file, otherwise file name is predefined by Revit’s setting.
