In this article you can find:
- Quick Renumber video
- About Quick Renumber
- The main features of Quick Renumber
- Workflow
- How to use Parameter Selection
- How to use Numbering
- How to Auto-Swap Numbers
- How to Continue Element Numbering
Quick Renumber
About this feature:
This is a tool that allows you to number elements using any shared text parameters by picking them in order or by using a drawn spline.
There are two numbering options:
1. Number by Selecting Objects
- To use this option for the elements numbering you need to picking elements one by one in the model.
- The text parameter will be immediately updated when picked.
2. Number by Spline
- To use this option for the elements numbering you need to have a spline that crossing the category elements in the model.
- The numbering will be done by selecting the spline in model from the start to the end point.
The numbering order depends on picking spline point, so tool will propose direction from closest spline end based on picking place.
Workflow
- Run command Renumber Elements
- Select one of the numbering options
- Select numbering parameter
- Enter current number
- Use options for padding, prefix and suffix
- Select object or spline at model view
- Click the close to complete process
How to use the feature
1. Parameter Selection
The numbering parameter can be selected from parameter drop down list. You can choose any of available shared parameters for the elements numbering.
The requirements to get parameter under the list is that parameter must be shared.
If the selected element doesn't have certain parameter selected for numbering, the tool will add that parameter to the element, and it will be sorted under the identity data.
2. Numbering
The tool can use a numeric or alphanumeric characters for numbering.
The characters are supported for single letter and/or multiple identical letters.
End the numbering command by pressing Close after you’ve picked the last element/spline to renumber.
The numbering selection is completed by highlighting the elements in the model.
To continue numbering select another spline in the model.
3. Auto-Swap Numbers
If the current number already exists in the project, the tool will inform you about that.
To avoid the repetition of the swap number messages, use the “Auto-swap element numbers” check box in the main dialogue.
4. Continue element numbering
You can continue element numbering starting from the element current number in a model.
To use this option, select the element type for numbering and click on the arrow button, and select the element in model to get next number.
The current number will be immediately updated with next number for numbering.
To increase or decrease the Current number press + or – button.
Notes and Tips:
Use the “Do not show again” option in the info dialog box, after finishing your selection, to hide the information dialog box about how many elements that will be renumbered when picking many Spline element after each other.
