In this article you can find:
- Video on Scope Box Synchronizer
- About Scope Box Synchronizer
- Main features
- Workflow
- How to use Scope Box Synchronizer
About this feature:
This is a tool used to import and synchronize scope boxes between linked projects.
The main features of the tool are:
- Selecting a Revit link with Scope Boxes
- Importing Scope Boxes from the other project
- Synchronizing the link’s Scope Boxes with yours
Before starting the tool, make sure that you have linked a Revit project that contains Scope Boxes. After importing a Revit link into the host project start the function. A dialog box will open that shows you how many Scope Boxes there are, which ones are located in the linked project and which are in use by the host project - providing an overview of just where you have used which Scope Box.
Workflow
- Select a Revit link with Scope Boxes. If any Scope Boxes are detected in the linked project you will have the option to Import them into your project - if the name of the linked project's Scope Boxes matches any of yours, the application offers to Synchronize the linked Scope Boxes to yours and make sure that all your views which are set to a Scope Box will be set accordingly.
- Filter Scope Boxes by name. The function allows you to filter the scope boxes by their name, or by status, and even filters the scope boxes which are pinned, grouped or checked out. This enables you to easily filter out the needed scope boxes making it easier to manager them.
- Import missing Scope Boxes from Link.
- Synchronize the link’s Scope Boxes with yours. After the link is imported and the desired changes are made to the scope boxes, or even some scope boxes get deleted, the function enables you to manage the changes in a semi-automatic way.
- Set the Display Order. Specify how the scope boxes should be sorted in the dialog box. Natural order is order alphabetically in the local project and then in linked project by date of creation. Link Element Order is order by element id in the linked file. Project Element Order is order by element id in the local project.
How to use
The dialog box clearly shows each scope box that has been deleted or changed in the project. It lets you decide which ones you want to manage. If a scope box is deleted in the project, those scope boxes will be marked with blue color, and if needed, the deleted/missing scope boxes can be retrieved from the linked project simply by clicking again on "Import missing" and the scope box will be re-imported to it's original place. If by any chance the Scope Boxes are moved or re-sized these changes will be marked with orange color, which means that the Scope Boxes in the host project do not match the scope boxes from the link, if there's is a need to change the host Scope Boxes to their original place and size that can be managed by clicking on "Synchronize Project Scope Boxes with Link's". The ones labeled with green color are those Scope Boxes that match the size and position of the linked Scope Boxes.
Filter by Name is used for filtering Scope boxes just by typing the desired name.
The status of the Scope boxes is managed with four options:
- Scope Boxes that are existing and equal in size and position both in the linked and host project
- Scope Boxes which exist both in the linked and host project but are different in size and Position
- Scope Boxes which are missing either in the host or linked project
- Scope Boxes which are Pinned, Grouped or Checked Out
The Usage column shows if a view is using that specific Scope Box.
Notes and Tips:
Scope Boxes can be set by:
- View (also 3D views)
- Reference Planes
- Grids
- Levels
