Naviate Tool Palette is missing
2 min. readlast update: 11.24.2025
If a Tool Palette is missing from your Naviate Tool Palettes, you can in many cases solve it yourself from inside the program. There are two methods to do this, Naviates built in Profile Setup or manually with Customize Tool Palettes. We recommed to first try Naviates Profile Setup and if that doesn't work, continue with the manual rebuild of tool palettes.
1. Profile Setup
Start by using Naviates Profile Setup (Naviate-Ribbon > General-tab > Help-dropdown or type NvProfileSetup)
In the dialog verify that Naviate Tool Palette Folder is ticked and that the correct search path is selected. Click OK and see if the Tool Palettes are reloaded.
2. Customize Tool Palettes
Start by Right-clicking on the Tool Palette-heading (at the top of the Tool Palette or on the side of the Tool Palette) and select Customize Palette.
undefined
The available Palettes are displayed on the left side of the dialog and the Palette Groups are displayed on the right side. You an drag and drop the palettes from Left to Right. You can also right-click on a palette on the right side to Remove it from the Palette Group.
undefined
Once a palette is visible you can right-click on that palette (you need to right-click in an empty space on the tool palette to get this right-click menu) and select View Options to change the size of the icons and set the View Style of the Tool Palette.
undefined
undefined
