As an architect it's often that when linking a fire safety model, there is a want to show nothing except wall compartmentations.
Turn off categories such as signage, fire alarm devices and security devices.
Wall compartmentation, fire doors and fire windows are of category Fire Protection, so create a simple filter to hide everything except wall requirements.
- Go to the View Template (if the view has one connected, otherwise jump to step three in visibility/graphic override):
- Edit View filter:
- Create/Add a view filter:
- Name the Filter and repeat the settings below:
- Select the newly created view filter and turn of visibility:
Press ok all the way out to the view again. - End Result:
