Publish before transfer fails
Symptoms
A job with publishing turned on fails at the publish stage, or the transferred model does not include recent changes.
Cause
- Users have changes in the cloud workshared model that are not synchronized with central.
- The model is busy, for example someone synchronizes during the publish.
- You don't have the permission needed to publish in the source folder.
- The file is not a cloud workshared Revit model, so it cannot be published.
Solution
- Ask the team to synchronize with central before the job runs.
- Schedule publish jobs for times when the model is not in use.
- Ask the Project Admin to check your permission level in the source folder.
- Use publishing only for cloud workshared Revit models.
For more about publishing, see the Nebula Publishing help page.
Revit links are broken after transfer
Symptoms
A transferred Revit model opens, but linked models show as not found.
Cause
Cloud links point to a specific project and file. After transfer, the links may still point to the source project, or the linked files were not part of the job.
Solution
- Include all linked models in the same transfer.
- Open the model in Revit and use Manage Links to reload each link from the destination project.
