The Naviate for Revit installations can be run silently from the command line. The command line syntax is as follows:
- msiexec /I “<msi>” /qb Will update if older 2018 version exists, preserving old settings
- msiexec /I “<msi>” <params> /qb Parameter controlled installation, parameters as follows
