You cannot sign in, or you are signed out during a session
Symptoms
The Autodesk sign-in page keeps reloading, or Nebula returns you to the sign-in page while you work.
Cause
Your Autodesk session has expired, or your browser blocks the cookies or pop-ups that Autodesk sign-in needs.
Solution
- Sign out of Nebula and sign in again.
- Allow pop-ups and third-party cookies for the Nebula and Autodesk sign-in sites.
- Try a private browser window to rule out cached sign-in data.
- If your company uses single sign-on, check that you can sign in to ACC directly with the same account.
Nebula reports that you have no licence
Symptoms
You can sign in, but Nebula shows a licence message and you cannot create jobs.
Cause
No Nebula licence is assigned to the Autodesk account you signed in with, or the licence has expired.
Solution
- Check that you signed in with your work Autodesk account, not a personal one.
- Ask your licence administrator to assign a Nebula licence to you.
- If the licence was assigned recently, sign out and sign in again.
A hub or project is not listed
Symptoms
When you choose a source or destination, the hub or project you expect is missing from the list.
Cause
The Nebula integration is not enabled for that hub, or you are not a member of the project.
Solution
- Ask the hub's Account Admin to enable the Nebula integration under Custom Integrations in ACC Account Admin or BIM 360 Account Admin.
- For another company's hub, their Account Admin must enable the integration. You cannot do this from your own hub.
- Ask the Project Admin to add you as a project member.
- Refresh Nebula after the change.
A folder is missing or access is denied
Symptoms
A folder does not appear when you browse a project, or the job fails with an access or permission error.
Cause
Nebula works with your own ACC or BIM 360 permissions. If you cannot see or edit a folder in ACC, Nebula cannot either.
Solution
- On source folders, you need at least View + Download.
- On destination folders, you need at least Edit.
- Ask the Project Admin to update your folder permissions, then run the job again.
