If at startup you get an error message as the one below with the text
"An unexpected error occured during login and license initialization.
Method not found "Void Microsoft.Extensions.Logging.LoggerFactory.AddProvider(Microsoft.Logging.ILoggerProvider)"
The reson is a mismatch between Naviates files and a secondary applications files.
This error is solved in Naviate 2025.3.1 - please download and install from Naviate.com/Downloads
To solve this issue manually, open the Program Files folder: C:\Program Files\Symetri\Naviate\Civil3D202x
And find the file Microsoft.Extensions.Logging.Abstractions.dll
Rename that file to Microsoft.Extensions.Logging.Abstractions.dll.bak
Then restart your Naviate.
