Article written from August 2024 and can change overtime.
When using Naviate Bimfire and want to use your own made symbols, here is a list of must-haves and the nice-to-haves.
All parameters which are sent to an underlying object must be an instance parameter, parameter type: String/Text.
Must-have
The symbols category must be one of these:
- Audio Visual Device
- Ceiling
- Communication Device
- Electrical Equipment
- Fire Protection
- Fire Alarm Device
- Floor
- Generic Model
- Mechanical Equipment
- Security Device
- Signage
- Space
- Speciality Equipment
- Roofs
Families (Family name - Type name)
Wall Requirement
It needs a line-based family of Fire Protection or Audio Visual Device.
Opening Requirement/Dense Compartments
DoorRequirement - DoorRequirement
WindowRequirement - WindowRequirement
Clash Detection
ClashCableTraySymbol - ClashCableTraySymbol
ClashDuctSymbol - ClashDuctSymbol
ClashPipeSymbol - ClashPipeSymbol
Tag Evacuation Symbols
Fire Alarm Device tag (must be of this category)
Parameters (Family name - Parameter name)
All parameters below are used when using Naviate Bimfire features to connect to underlying object. Manually drawing requirements or using Naviate Family Shortcuts will not populate these parameters.
- DoorRequirement - FireReq_FireRatingDoor
- WindowRequirement - FireReq_FireRatingWindow
Fire Alarm Devices & Fire Alarm Devices Tags must have the Type Parameter "Fire_FamilyTagMapping"
Number of People
- Space - NVFloorSpaceFactor
- Space - NVMinClearWidthFactor
- HVAC Zone - FireReq_MaxNumberOfOccupants
- HVAC Zone - FireReq_MinClearWidth
Nice-to-have
NVAuditTrailStatus - Used with Audit Trail and Tag element feature, can be used to colour the different statuses in different colours.
NVLinkedElementID - Underlying objects Revit ID
NVGUID - Underlying objects Global Unique ID
NVLevel - Underlying objects connected level, used in schedules to sort by level due to a lot of symbols don't have the parameter Level but Workplane instead.
NVTypeMark - Underlying objects Type Mark, is used to understand what kind of object/classification the objects have.
NVTypeName - Underlying objects Type Name, is used to understand what kind of object/classification the objects have.
Wall Requirement
- NVHeight - Copies the unconnected height of the wall to mimic the underlying wall.
- NVWallWidth - Copies the wall width value as a string for schedules.
- NVWallStructuralMaterial - Copies the wall's structural material value as a string for schedules.
Clash Detection
The required clash families can have these values optionally populated:
ClashPipeSymbol
- NVPipeMaterial - The material assigned in Revit material.
- NVWallStructuralMaterial - The value on the compartmentations parameter NVWallStructuralMaterial which is the underlying walls assigned structural material.
- NVSlope - The slope of the pipe.
- NVWallWidth - The value on the compartmentations parameter NVWallwidth which is the underlying wall's assigned structural material.
- FireReq_FireRatingPipe - The FireReq_FireRatingWall value on the compartmentation copied onto the instance by default.
- NVOverallSize - Copies the parameter value of Overall size from the pipe as a string.
- NVPipeDiameter - Copies the parameter value of Pipe Diameter from the pipe as a string.
ClashDuctSymbol
- NVSlope - The slope of the duct.
- FireReq_FireRatingDuct - The FireReq_FireRatingWall value on the compartmentation copied onto the instance by default.
- NVDuctDiameter - If the duct is round, it copies the diameter parameter value as a string.
- NVDuctHeight - If the duct is rectangular, it copies the height parameter value as a string.
- NVDuctWidth - If the duct is rectangular, it copies the width parameter value as a string.
- NVInsulationThickness - Copies the parameter value of the Insulation Thickness as a string.
- NVOverallSize - Copies the parameter value of Overall size from the duct as a string.
- NVSlope - The slope of the cable tray.
- FireReq_FireRatingCableTray - The FireReq_FireRatingWall value on the compartmentation copied onto the instance by default.
- NVCableTrayHeight - Copies the parameter value of the Cable Tray Height as a string.
- NVCableTrayWidth - Copies the parameter value of the Cable Tray Width as a string.
Audit Trail
