Complete workflow as an Architect
2 min. readlast update: 11.21.2025
This workflow works for every stakeholder who needs information from the specialists in the project. The workflow below describes how it works if the architect works in Autodesk Revit.
Want to read more on how to use the data in day-to-day work? Read more here:
  1. Download and install the latest receiver.
  2. Import the parameters provided by the specialist. Both the specialist model and the architect model need to have the same parameters.
    1. Once loaded, make sure the parameters "may vary by group instance" in project parameters.
    2. All of these parameters should be correct by default when delivered from the specialist, all parameters must be text-based to be able to vary by group instance.
  3. Link the specialist model, to origin to origin, all symbols are visible as it would be in the specialist model. This is only 3D geometry, and no data has been transferred.
  4. Use the installed receiver to load the parameter values from the specialist model to the objects in the model.
Note: Repeat step 4 when a new specialist model is received. If the Architect model is opened when the linked file is replaced, it's necessary to reload the link first.
