The process for managing licenses changed for Naviate for Civil 3D licenses when the version 2023.1 was released.
This license system is used in Naviate for Civil 3D 2021.22, 2022.21, 2023.1 and all subsequent versions. All releases for 2024 and 2025 uses this system.
Content
- Create a Symetri user ID
- Naviate for Civil 3D licensing system
- Symetri License Portal
Create a Symetri User ID
- You can create a new account when you have installed Naviate and are asked to log in
- Accounts can also be created for multiple users by the license administrator at your company using the new Symetri License portal.
First time you start Naviate for Civil 3D 2023 you will be prompted to log in. Either use existing account from Naviate.com, use Sign Up to create a new account, or use an account that the License administrator at your company has created for you.
The account you use will determine which of the installed Naviate applications you will have access to use. If no license is assigned to you, a 30 day trial license will be activated.
The log-in is remembered on the computer until you logout from Naviate. You will not need to login every time you start Naviate.
You need to have internet access to create an account, log in and activate your license(s). After that you can run Naviate without internet access depending on your license type.
Naviate licensing system
Naviate for Civil 3D 2023 applications uses a new licensing system based on the Symetri User ID. The Naviate licenses you have bought have to be assigned to user accounts (Symetri User IDs). This is managed in the Symetri License portal (My.Symetri.com)
If you have purchased Naviate licenses; you use the Symetri License portal to assign licenses to users. You need to be an administrator in the Symetri License Portal to do this. One person in your company (the contract administrator) has this access but it can be added to multiple users.
Single-user license
- The single user license is personal
- It can be used off-line once activated
- The offline period is maximum 1 month without need for being online
- You can have the single user license activated on two computers, but you are not allowed to use them simultaneously
- It is possible to deactivate the license on a computer and activate on another computer
- The license is time-restricted based on your contract and is automatically updated when renewed
Multi-user license
- All users assigned to the license share a pool of seats
- A seat is taken from the pool when you run a Naviate command for that module
- If all seats are taken, you will not be able to run the command until a seat has been returned to the pool
- A seat is returned when closing Civil 3D or when logging out from Naviate
Trial license
If you do not have a license, you can start a trial license. The Trial is valid for 30 days and can be activated once per computer and user. Once you have started a Trial you can use the Naviate application off-line during the trial period.
Symetri Licence portal
The Symetri Licence portal is a web application that you can start from Help-button in Naviate or by using the link: My.Symetri.Com Use your Symetri User ID to sign in.
As a user you can:
- See started trial versions
As a license administrator at your company you can:
NOTE! The licensing system has been updated in november 2024. For more information about this, please see this page: Naviate for Civil 3D Licensing Changes | Naviate website Help Center
