The process for managing licenses changes for Naviate for Revit licenses on version 2022.1.1 and newer upcoming releases, here's an overview.
Content
- Create a Symetri user ID
- Naviate for Revit licensing system
- Symetri License Portal
Create a Symetri User ID
- You can create a new account when you are asked to log in
First time you start Revit after installing Naviate 2022-2025 you will be prompted to log in. Either create an account, use existing account for Naviate.com or an account that License administrator at your company has created for you.
Naviate licensing system
Naviate 2022 - 2025 applications uses a new licensing system based on the Symetri User ID. The Naviate licenses you have bought have to be assigned to user accounts (Symetri User IDs). This is managed in the new Symetri License portal.
Single-user license
- The single user license is personal
- It can be used off-line once activated
- The offline period is maximum 1 month without need for being online
- You can have the single user license activated on two computers, but you are not allowed to use them simultaneously
- It is possible to deactivate the license on computers and active on other computers
- Reach out to support or your contact in SYmetri to get help to deactivate a computer.
- The license is time-restricted based on your contract and is automatically updated when renewed
Multi-user license
- All users assigned to the license share a pool of seats
- A seat is taken from the pool when you run a Naviate tool for that application (or when running a tool in Naviate Accelerate)
- If all seats are taken by other users, you will not be able to run the tool until a seat has been returned to the pool
- A seat is returned when ending Revit/Naviate or when logging out from Naviate
Trial license
Symetri Licence portal
The Symetri Licence portal is a web application that you can start from Help ribbon in Naviate or by using the link: https://license.symetri.com. Use your Symetri User ID to sign in.
As a standard user you can
- See started trial versions
