Naviate MEP and Fabrication are now available for Revit 2021 through 2026
We are pleased to inform you that with the release of Naviate MEP and Fabrication version 3.10, it also is now compatible from Revit 2021 through 2026. Please refer to the install/uninstall steps below for the best experience when installing version 3.10.
For more information regarding the new features and functionalities in version 3.10, please visit our Release News website at https://www.naviate.com/release-news/
Installation of Naviate Core.MEP.Fabrication v3.10
Prerequisites:
All instances of Revit must be closed before running the msi installer of Naviate Core.MEP.Fabrication.
Uninstall previous versions of Naviate MEP, Fabrication, and Core. See “General Notes regarding v3.10 installation” below for more information.
Delete old versions of Naviate dll’s. More information can be found below.
The 3.10 installer (click here for link to download) comes with the following Options to install:
Naviate MEP for Revit 2021 – 2026
Naviate Fabrication for Revit 2021 – 2026
Naviate Core for Revit 2019 – 2022
NOTE: Naviate Accelerate can be installed with a separate installer for each Revit version.
2022
2023 – This version includes all Core functionality
2024 – This version includes all Core functionality
2025 – This version includes all Core functionality
2026 – This version includes all Core functionality
Steps for Naviate Core.MEP.Fabrication installation
After downloading the Naviate Core.MEP.Fabrication - V 3.10.msi file to your machine, double click the .msi. Launching the .msi opens up the Setup Wizard dialog.
Click Next to continue; click Cancel to exit the Setup Wizard.
Please read the following End-User License Agreement carefully.
- Click the checkbox to accept the terms in the License Agreement; click Next to continue:
In the Custom Setup, you have the option to decide which version(s) of Revit you would like Naviate installed.
Click the checkbox next to each version of Revit to remove or add from the installation; click Next to continue.
Alternatively click the Reset button. This will automatically identify which versions of Revit on your machine Naviate can be installed for.
User Account Control prompt – your machine may ask for permission to proceed in the installation. Click Yes to continue the installation process.
If there are any active sessions of Revit open, user will get the following pop up, prompting to close Revit:
Files will be copied onto the machine. Click Cancel to cancel the installation process.
Installation is complete. Click Finish to exit the Setup Wizard. Naviate is now officially installed on your machine.
Installation of the latest version of Naviate Accelerate
Before or after installing Naviate Core.MEP.Fabrication v3.10, it is recommended to download and install/update to the latest version of Naviate Accelerate. The most up-to-date installers can be found at https://www.naviate.com/downloads/
Uninstall Previous Versions
Before installing Naviate Core.MEP.Fabrication v3.10, it is recommended to uninstall the following applications. Search for these applications in “Add or Remove Programs” and please uninstall.
Naviate Core.MEP.Fabrication – any previous version
Naviate MEP 2023, 2024, and 2025
Naviate Fabrication 2023 and 2024
Naviate Help 2023 and 2024
It is recommended to delete any obsolete/discontinued .dll files located in the Symetri Program Files folder. Please see the steps below along with screenshot, indicating which files to delete on your machine.
Windows Explorer - navigate to C:\Program Files\Symetri\Naviate\Revit 2023\Dll
Delete .dll files that begin with "NaviateFA" or "NaviateMP".
If files exist at the path C:\Program Files\Symetri\Naviate\Revit 2024\Dll, repeat Step 1 for the 2024 path.
