After installing Naviate Rebar Extension 2022, Revit stops working and you are not able to run it anymore.
Solution
You need to make sure that you at least are running Revit 2022 version 22.0.10.28 or newer.
Naviate Rebar Extension is relying on that Autodesk REX Framework that was relased in a hotfix / update in beginning of July 2022.
