This information is for Naviate for Civil 3D 2023.1 and forward and Naviate for Revit 2022.1.1 and forward.
If you want to test Naviate then you can use a trial license for 30 days. The installation package can be found on Naviate.com/downloads. You will be prompted to login or create an account. When you have created your account, you need to verify your email before you can download your Naviate installation package.
Click on the Naviate package you want to install, and then select the version you want to download and any applicable Patches/hotfixes.
Once your Naviate installationfile is downloaded, double click on the MSI-file to start the installation wizard.
When Naviate is installed, the first time you start Naviate you will be prompted to log in, this is the same account that you created on Naviate.com.
If you downloaded a trial without creating an account on Naviate.com, then you can create an account at the first start of Naviate. Note that you then need to restart Naviate after you have verified your email and your account is active.
Your trial will start as soon as you click on a Naviate command.
