7. FAQ Revit for Fire Engineers
Complete workflow as an ArchitectComplete Workflow as a Regulatory specialistLoad Parameters from SpecialistImport From LinkImport from Link - Switching element type to curtain elementImport From Link - Could not retrieve Import Mapping parameters from linked modelTips & Tricks: Leveraging Imported Specialist DataGetting Started with Naviate BimfireError at startup - External Tool FailureCreate Evacuation TagsNaviate Bimfire Revit TemplatesNaviate Bimfire FireReq Shared ParametersDeliver a Revit Specialist ModelCheck-list before deliveryUse titleblock from linkUpdate linked modelSend Parameters from SpecialistCreate Sheets and Place ViewportsOverlapping level heightsHorizontal Compartmentation - Model In-PlaceHorizontal Compartmentation - Copy/MonitorHorizontal Compartmentation - MonitorImport MappingsQuality Assurance - Linked objectsUsing the Unconnected Views To Find Unconnected ObjectsUser Defined Property SetExport IFC From Specialist ModelSlanted Compartmentation - i.e. stairs, ramps Imprint_Export_Options_Json "CQTP"Roof Compartmentation[IFC] IFC Mode can't select wallsLegend scheduleCalculate Travel DistanceUpdate Type ImageOnly show wall compartmentationHow-to use WallRequirement_AdaptiveSoffitCompart for irregular wallsQuality Assurance - Create View FiltersEvacuation RouteUsing own symbols - Requirements[IFC] Workflow when working with an ArchiCAD IFC[IFC] ArchiCAD requirements on the IFC"A login is already in progress"Error in Naviate Login: Unknown error accurred during authenticationStart-up crash, Revit cannot run the external application "NaviateB"Change graphics on wall requirementsCreate compartmentation for stairsEvacuation Plans - Orientation symbol/Site plan
